This command clears only frame-loss information for segment with given segment name for all associated MEPs.
segment_name |
An alpha numeric string identifying the segment name. |
N/A.
Use this command to clear only frame-loss information for segment with given segment name for all associated MEPs.
# clear co cfm seg cs10 frame-loss # # # # sho cfm seg cs10 CFM Segment Name : cs10 Domain Name : dom1 Association : a10 MD Level : 1 Destination MAC : 00:04:96:52:a7:38 Frame Delay: DMM Transmission : In Progress Transmission Mode : On Demand Total Frames to be sent : 45 Frames Transmitted : 1 Pending Frames : 34 Frames Received : 1 DMM Tx Interval : 10 secs DMR Rx Timeout : 50 msec Alarm Threshold : 10 % Clear Threshold : 95 % Measurement Window Size : 60 Class of Service : 6 Tx Start Time : Mon Mar 12 10:28:19 2012 Min Delay : Mon Mar 12 10:28:19 2012 Max Delay : Mon Mar 12 10:28:19 2012 Last Alarm Time : None Alarm State : Not Set Lost Frames : 0 Frame Loss: LMM Tx Interval : 10 secs SES Threshold : 1.000000e-02 Consecutive Available Count : 4 Measurement Window Size : 1200 Class of Service : 6 Total Configured MEPs : 1 Total Active MEPs : 1 MEP ID : 10 LMM Transmission : In Progress Transmission Mode : On Demand Total Frames to be sent : 45 Frames Transmitted : 1 Pending Frames : 33 Frames Received : 1 Availability Status : Available Unavailability Start Time : None Unavailability End Time : None Tx Start Time : Mon Mar 12 10:28:29 2012 ----------------------------------------------------------- Total Configured Segments : 11 Total Active Segments : 11 # # # # #
This command was first available in ExtremeXOS 15.1.
